Thread: issue update
Old May 14, 2024 | 08:45 PM
M60A3Driver
Default Re: issue update
Originally Posted by ZERACER
Actually no, it has been sitting. After replacing the RCM, CPS and Maf, it would sort of idle however no power and loud popping when running. It sounds like a hole in the manifold. There is also what appears to be a hot spot on the exhaust manifold which could indicate a cracked or broken valve.
I found a thread about a line that runs to the bottom of the intake manifold near the throttle body. The fitting that the line goes into gets dry rotted and causes leaks. I don't know if that is causing the trouble.
You can find it around post #85 in this thread:
https://www.crossfireforum.org/forum...running-5.html
