Thread: What Happened ?
Old Oct 12, 2006 | 05:12 PM
MMZ_TimeLord's Avatar
MMZ_TimeLord
Default Re: What Happened ?
I will respond to the off topic conversation here...
I had no problem installing the cargo cover in my Crossfire.
The main trick to getting the rear hook anchors in place is to carefully measure and drill the holes in the plastic cover per the template supplied with the kit.
Then secure the anchor arm with the main bolt left slightly loose. Then, by reaching through the small access area to the anchor, you can swing it up so the holes line up. I found it was much easier to sit cross legged in the rear cargo area to do this.
If this is not an option then you will find yourself bending over the hatch rim and trying to view and struggle with the anchor.
Using a fluorescent drop light in the cargo area will also make it easier to see the holes line up.
Good luck.
