Old May 24, 2024 | 02:06 PM
  #41 (permalink)
BobG's Avatar
BobG
Default Re: My H7 bulb headlight saga
Went to the Lasfit site as suggested by Nelson G and found two all-in-one bulbs: the H7 6000LM LCair Series and the H7 7000LM LAair Series.
What's interesting is that this text appears on the H7 7000 LM LAair Series product description, but not on the H7 6000 LM LCair one:
● The OEM rubber dust cover can be put back on
Lasfit LAair series H7 LED bulbs are the perfect solution for vehicles with small headlight housings and round-bottom LED bulbs that come with a separate power cord, leading to a larger size and height that prevents the OEM rubber dust cover from being placed back on. This can create concerns about dust or water getting inside the headlight housing. With Lasfit LAair series H7 LED bulbs, such worries become a thing of the past, as they are designed to fit seamlessly with the OEM rubber dust cover and prevent any dust, water, or debris from entering the headlight housing.
Nelson G: Were you able to put the dust cover back on over the H7 6000LM LCair? I assume so, but would like confirmation. Thx
