Old May 24, 2024 | 03:10 PM
Rewdog's Avatar
Rewdog
Default Automatic Coupe - No drive just revs
I've got a 100k Coupe, no idea on it's history.
I was driving along and pulled up to some traffic, I stopped for a few seconds but when I went to pull away, the car just revved when I depressed the throttle. I turned the car off for about a minute, when I fired it back up, I had drive again but only for about 10 seconds. This happened 2 or 3 times until I gave up and got rescued.
I asked in the groups on Facebook and based on the codes I was getting in my very cheap code reader (P0715 - Input/Turbine speed sensor A circuit and P0730 - Incorrect gear ratio) I had the conductor plate replaced, along with connector, O rings, pan and new ATF.
After this has been done the car still had no drive, i did the throttle reset based on advice I was given, I've put the code reader back on and now it has no codes. Not sure how much a £20 device off Amazon can be trusted though.
The mechanic who did the work for me said he put the same amount of ATF in as he took out, the car is parked (and undriveable) on a slight incline, I have a dipstick but obviously not getting a clear reading because of the slope (only a few degrees).
Any help appreciated, I bought her, did 250 miles and enjoyed every one of them, polished and made her beautiful but is now just a paperweight! I haven't actually tried to drive it, the mechanic did though, you can hear it go into reverse etc.
