Old May 25, 2024 | 12:54 PM
  #45 (permalink)
M60A3Driver
Default Re: My H7 bulb headlight saga
Originally Posted by LLzel
With a little help from my friends here, I replaced the front low beams and the front turn signals. Pretty easy glad I had the 90 degree needle nose players. Dust cap on fine. I tried the high beams but the radiator overflow tank is in the way and I didn’t want to empty and remove it, not even sure how to empty it. Plus the lamp is in a deeper compartment then the low beams. I would like to replace the eye lid lights. So I’ll read again the link that Nelson posted. The low beams and turn signals are bright. Next I’ll attempt the rear lights. Any trick in removing the trunk covers to get to the lamps?
I’m liking this crossfire more everyday.
I didn't empty my overflow tank. I just moved it out of the way. It's held in by two 10mm nuts, and a rubber grommet goes through a hole under the tank. Tip: spray the grommet under the tank. This will make it easier to remove and put back.
Here's a post I just did:
H7 LEDs
