amx1397
it a srt6 or limited,, all TCU"s interchange but only limited to limited or srt6 to srt6 in case u need one from junk yard.
also have u disconnected the battery for about 1 min, and pump the brake peddle to discharge the system. then reconnect the batt.
the computer the mechanic has has to ask for a 2002 slk 32 (if your car is a srt6 or a c320 / slk320 for the limited.
Not sure where the response I typed has gone. Thank you for responding.
It is a standard Coupe nCoupn SRT. What does the battery disconnect and brake pump do?
The mechanic tried various Mercedes SLK320 versions, he also tried using the VIN. He was questioning if his code reader linked to his phone was even working.
