Thread: Error code
Old May 27, 2024 | 05:07 PM
Valk
Default Re: Error code
Originally Posted by CabinIsle1
Error code “wrench “-222 shows in odometer when I start my car. What does it refer to?
It is telling you you are 222 miles past due for your oil and filter change
Once this is done it can be reset to display 7000 by following these steps
RESETTING THE FSS MAINTENANCE INDICATOR AFTER AN OIL CHANGE
1) Move the ignition switch to the “RUN” position
2) Within 4 seconds of moving the ignition switch into the
“RUN” position, press the reset button for the trip odometer
twice within one second The display for the FSS service
request is activated for 10 seconds
3) During the 10 seconds the FSS service request is displayed,
move the ignition switch to the “OFF” position
The FSS service request will continue to be displayed
4) Press the reset button for the trip odometer and
hold
5) Move the ignition switch to the “RUN” position
6) Continue to press and hold the reset button for the trip
odometer (about 10 seconds) until the audible signal
sounds and the new start distance appears in the display
The tool symbol should disappear at this time
