Thread: Softtop problem
Old Jun 4, 2024 | 01:53 PM
nickwe21's Avatar
nickwe21
Default Re: Softtop problem
Solihull? That is not a location - note how I put "Fort Worth, Texas" to make it clear where I am.
If you are in the UK or EU, I don't know of anyone. If you are here in the USA, we have several people scattered around the country that can reglue the window (it won't last but if you insist on trying and throwing $200-$400 away....) or that can replace the top for no more than $300 labor. The top is currently running $800USD, delivered in the USA.
Your top is close to 20 years old - it is time for a new one - I glued mine four times and had enough.
Always wondered if there is anyone who glued it and actually got decent results (long lasting results). Maybe if it is caught very early and only on the inside, it could be "reinforced" but I think once it starts to really separate there is only one option - get a replacement!
Most seem to go with BAS (UK company) and most likely due to the price factor. There are some others who swear by the EzTops, which seem to be cut better and have the window stitched into a pocket so you do not have to worry about the glue coming apart anymore. They are more expensive though. Both are used quite frequently.
If you are handy, you can replace it yourself (there are videos online - it's actually fairly simple). I did it with a very nice forum member once and then was confident enough to help a friend replace his. Two people come in hand for the job but it's worth it.
