Re: 2004 Crossfire - Electrical nightmare - HELP
The weird part is, until I pulled and replaced every fuse in the fuse box, I didnt have a problem with the car starting and running. When I found the parasitic drain fuse, I left it out, hooked the negative cable again, and tried to start the car. The engine turned over a few time and then nothing. It wasnt a slow turn over like a dead battery, it was trying to start for a few revolutions and then it just stopped turning over. So I disconnected the negative cable again, put the # 35 fuse back in place, and it turns over, but just wont start. It acts like its not getting spark. I could smell fuel, so I know its not a fuel issue. Will messing with the fuses, affect the RCM. Will it mess with the Skreem? I had no issues prior to this other than the parasitic battery drain.
