Old Jun 8, 2024 | 01:42 AM
M60A3Driver
Default Re: 2004 Crossfire - Electrical nightmare - HELP
Originally Posted by Vetteguy
Don't understand the question. I had the negative cable off, used the multimeter between the battery and the negative cable end, so the draw was going through the multimeter. Once I found that pulling the # 35 fuse reduced the draw, I pulled the fuse, connected the negative battery cable, and tried to start the car, which is when it turned over 3 or 4 times, then nothing. So I disconnected the negative cable again, replaced the # 35 fuse, then reconnected the negative battery cable, then tried to start the car and it turns over, but doesnt start, like its not getting any spark, because I can smell fuel, but wont start.
When you pulled fuse #11 it may have broken. This happened to me with the #9 fuse when I pulled it out. Try using an ohm meter on it and see if the fuse is good.
