Relays in the Fuse Box
The temperature and time lights stay on in the cluster panel at all time. When the car is running, the lights from those two are brighter than the rest on the panel.
I have been disconnecting the fuse (#35) to prevent battery drain whenever I parked overnight.
I'm wondering if the problem has something to do with the black Turn Signal Relay A002 542 21 19 in the fuse box; the yellow relay next to it is supposed to be for the washer pump A002 542 14 19.
Can somebody please confirm my suspicion in regard?
Btw, my remote control stop working at about the same time.
P.S. I have just removed both relays in the fuse box but the lights are still lit. It's not the relays.
Reason: additional info
