A bit of advice on expectations. I did a glue job using the 3m glue but did not use a primer. I used an other glue in between the fabric flap. It held about 9 months. My top is most likely original. I think the process of putting the up and down put's extra stress on the fabric at the rear of the window causing it to break loose in the corner. So don't be surprised if does not last.
Here is my post on my window glue up:
https://www.crossfireforum.org/forum...w-glue-up.html
