Old Jun 29, 2024 | 02:06 AM
M60A3Driver
Default Re: Trying To Replace A Fuse On My Crossfire Fuse Box Looks Different
Originally Posted by Wyliecoyote
Hi there mate I have a similar problem as the speedometer has stopped working and spoiler is stuck up, did changing the fuse fix the problem with your car by any chance? Or did it become something else that was the issue, please any bit of help and advice will be greatly appreciated believe me on that as I'm starting to panic over all the little things that are just now popping up but tbh when driving the car it's so smooth it's like a different car completely. Hope you can make it through my essay and get back to me. Cheers mate
Regards
​​​​​​Andrew Wylie from Newcastle upon Tyne.
The fuse for the spoiler/wing is # 16 on a USA car. That would be for the spoiler only, but I would think it would stay in the down position if it was the fuse. It could also be a bad speed sensor for both the speedometer and the spoiler.
Also you might want to use a scanner to see if any codes come up. That will give you the best information.
