Thread: Pedal Commander
Old Jul 12, 2024 | 12:13 AM
M60A3Driver
Default Re: Pedal Commander
Originally Posted by hillcountryflyer
After the trip to the Ozarks event I came home with a list of things I wanted to fix or change on the roadster. One of the bigger items was the lag coming out of corners. A supercharged car should not have that problem. I opted to install a Pedal Commander and wanted to share my thoughts. The install was simple once I figured out how to remove the pedal assembly. I started off in city mode, position 2. Quickly decided what the hell kick it all the way to 4. Wow I am impressed. No more lag. On the flip side the throttle is pretty twitchy so I will have to get used to that. Another thing I learned is that the car does not decelerate like before and I have to get on the brakes quicker. That makes sense as the computer is now getting an altered signal from the pedal. So if you make a banzai run to 80 or 90 it is going to hang at that speed for a few seconds longer.
Overall it performs as advertised. I am going to run it on the car for a while and see how I like it.
Thanks for sharing your observations of how it performs. I doubt I'll get one (base model), but it's good to learn about different things.
