Old Jul 16, 2024 | 01:14 AM
M60A3Driver
Default Re: Would you please help?? Metallic noise(static) sound under the car in the rear(a
Originally Posted by Clpangee
Hello everyone and masters,
I have been very stressful due to metallic nosie(static) coming up from under the car as attached AVI files.
I think it comes from rear. (not front).
So, I changed the 'Hub bearing' to rear at the repair shop. (It costs 330 USD)
But, Failed. (Just same as before)
Would you please please... help me and let me know which parts am I have to change? except Hub bearing.
Would you please listen carefully attached 2 files?
Your advise will be very helpul to me.
Thanks in advance.
If it's not the wheel hubs, it might be the rear parking emergency brake.
Have you installed new wheels on your car? The wheel bolts may be to long and might be scraping on the inner emergency brake parts.
Try jacking the rear so that the rear tires do not touch the ground. Safety First! Use jack stands and block the front tires so the car does not roll.
Turn the tire by hand. Listen for any noises while you are turning them. Also check your axles that go from the differential housing to the wheels.
I hope that this helps.
