Old Jul 17, 2024 | 12:33 AM
M60A3Driver
Default Re: Computer Control Relay
Originally Posted by rbasm
My intent is not to annoy anyone. If I'm not using the right terminology, I'm sorry. So let me try again. The On-Board Dianostics port under the dashboard on the driver side is not giving me a reason why it will not pass NYS inspection. No code indication. I have put over 250 miles on the car since it first failed and have brought it back 5 time to the inspection station to no avail. I did change RCM 6 months ago and the only thing I wanted to know is, in your opinion does the RCM have anything to do with the information that the OBD-II reads. If I'm not expanding myself correctly, I'm sorry, just looking for advice.
I'm trying to help, so let me ask you these questions.
When the tech says that your car failed, did they tell you what they were failing you for?
Are you going to a state inspection center or a private one?
https://www.tlcautotruck.com/blog/th...le-inspection/
https://vehq.com/things-that-fail-car-inspection/
