Old Jul 23, 2024 | 12:08 AM
GraphiteGhost
Default Re: How to remove the pins from the throttle body connector?a
Originally Posted by JaNeily
Got it. Since the connector was shot anyway, I just cut away the outside with a small side cutting pliers, and then I had access to the tabs that hold the pins in. Pressed them in with a small screwdriver, and the wires came right out.
MAKE SURE you GENTLY bend those tabs back out so they re-click into the NEW connector case. Otherwise, one or more bay 'back out' of said new connector. Might save some headaches down the road.
