re: Dashboard not lighting up; car wont stay running
My issue is similar to the issue with the key not being recognized. The car starts and then cuts off immediately. After 3 tries it doesn't start again unless I remove the negatve cable from the battery.
Also, my dashboard instrumental panel will not light up other than the battery indicator light.
Also I can manually lock the driverside door, however the passenger side doesn"t lock in unison
I thought it maybe the auto-theft that was somehow triggered when we removed the driverside window motor. Not sure even how to check. I have reviewd comments about the SKREEM device being a factor in this scenario.
