pizzaguy
SPec is nothing more than .055 amp, if you are seeing .24 amp, you have a huge problem. TO BE CLEAR, this is a current reading with the meter in series with the battery ground lead, on the 10amp scale-is that correct?
DOH! Sorry, decimal point off - meant to type .024. Thanks for catching that, fully knew should not be more than .055, the reason I overlooked it. Was just typing to fast to note I cleared that test.
