Old Aug 10, 2024 | 02:33 PM
M60A3Driver
Default Re: Central lock system only works while engine is under load
Originally Posted by jawa78
Fixed:
While not listed on the fuse sheet, I went to fix a different issue: no map lights in the interior, I pulled fuse #9, and it was burnt out. replaced it had map lights and then magically the door locks started working with the engine off.
I'm glad that you've solved the issue. Thanks for the update!
