Thread: issue update
Old Aug 13, 2024 | 03:14 PM
zip439's Avatar
zip439
Default Re: issue update
Originally Posted by ZERACER
Thanks for the feedback. I also figured excessive fuel in the system but have no other ideas what would cause that. I also changed the EVAP solenoid that regulates the fuel return so ? I tried adding suction to it and nothing.
If the charcoal filter back by the fuel filter and pump gets saturated with gasoline the EVAP system will pull raw gas into the intake manifold when the solenoid (under the hood, in front of the CAB) opens.
The EGR should only circulates exhaust fumes back to the intake manifold.
As I said above you may have got the problem taken care of, but watch the EVAP system for any trouble.
The solenoid is normally closed; Adding vacuum to it should be negative, but adding vacuum to the line that runs to the rear of the car is what you want to test.
