Thread: P0300 easy fix
Old Aug 15, 2024 | 01:04 PM
GraphiteGhost
Default Re: P0300 easy fix
Originally Posted by DerrickRL
My car cutting out at 2000/2500 rpm.
My car would crank but not start, got fault code for Crank sensor, replaced it, after few miles same thing, removed sensor and slight damage on sensor, replaced it. Started fine, drove for about 20 minutes and car cut out. Now car will start but won't rev over 2000/2500 rpm, it just dies, When it hits 2000rpm I get a loud 'bang' through exhaust and then engine dies.
I bought new relay module and PCM as thought it might be one of those, only to find out you can't programme them without special software and having trouble in UK to find someone.
I'm now thinking bad Lambda sensor or collapsed Cat' Convertor.
any one please assist.
Did you use an OEM Bosch sensor? These cars do not like non-Bosch sensor parts. Hope you track it down!
