Re: Car Not Turning Over After Reading and Erasing Fault Codes
Hi,
Car starts but won't run over 2500rpm, Bought second hand RCM, fitted it and nothing worked, so that appears to be a 'dud'.
Working on it today, followed all instructions in workshop manual for checking Crank Sensor, next step tomorrow to pull the CPS again.
Noticed in manual it says replace Tone wheel but i suspect that is a gearbox out job, the tone wheel looks about £/$10 but will cost me a fortune if gearbox has to come out.
Anyone know what the resistance is if you measure across the CPS to check if it is good or bad rather than just spending $60 each time on a new CPS.
I still haven't seen on line anyone else with the rev limit issue? Any ideas?
