Re: Car Not Turning Over After Reading and Erasing Fault Codes
Hi.
Only fault code that shows is for crank sensor P0335 when car stalls and engine light comes on. Codes clear, car starts, ticks over but if revved cuts out and same fault code appears. Second hand RCM was worse than mine so sending that back as was under a 7 day warranty along with PCM. Everyone I spoke to in the UK is baffled by the not revving over 2500 rpm, no one seems to have come across that fault but found a discussion on this sight about the lack of revs and the fix was cleaning the CAT, so i really think i have a number of issues going on.
Spoke to a Crossfire parts specialist in UK and they said 3 possible causes, CPS, Bad connector or cable, bad PCM. I followed all of the instructions in the workshop manual to check voltages, etc and cannot find anything wrong. Manual suggests replacing CPS.
I found a specialist in UK that repairs ECU's (PCM) but they said they have problems with the codes for Crossfires, so said they will look at it for me and if they can't find problem and fix it they will not charge me.
Bought third CPS today, which again is a BOCSH (second was a BOSCH) and will pull that to see if I can see anything that has caused the problem and fit the new one.
The Crossfire is a fairly rare car in the UK so finding anyone who knows how to fix them is difficult. I've had mine 10 years now and always been able to solve problem but this one has me beat. I'll try the owners club, thanks for the suggestion.
