Non-Stop Horn!
Hi y'all
I am currently in the process of diagnosing why the radiator fan on my 2004 XF doesn't work, when I apparently causes another issue. First, I jumped the fan motor directly, which actually works, and then checked the 50 amp fuse with an ohmmeter, which seems fine. During this process, I now have a situation where the horn comes every time I start the car. Nearest I can conclude is I somehow jarred the RCM while checking the fuse. The negative battery cable was off when I did all of this, and I unbolted the fuse before checking with the multimeter.
Any thoughts!
