Old Sep 9, 2024 | 06:14 PM
Rrwebster3's Avatar
Rrwebster3
Default Re: Help!!! 2005 crossfire, replaced throttle pedal, no rpms
Originally Posted by ZERACER
Why was the throttle pedal replaced and where did you get it, new or used?
The scanner said it was bad and the first one came from a junkyard and it was bad the second one came through eBay used and it no longer is reported as bad however it also doesn't cause the engine did run anything higher than 2100 RPM
