Rrwebster3
The scanner said it was bad and the first one came from a junkyard and it was bad the second one came through eBay used and it no longer is reported as bad however it also doesn't cause the engine did run anything higher than 2100 RPM
Have you tried the "Throttle Reset"?
1. Get in your car, shut the door.
2. Turn the key to the on (not start) position, the position just before the starter
turns over.
3. Press the gas pedal to the floor with the key in the "on" position.
4. Hold the pedal to the floor for five seconds, then turn the key back
to the "off" position (don't remove the key), then release the gas
pedal.
5. Wait 2 mins. for a full alignment.
6. Drive the car as you always do.
