Re: Headlight issue
Yes the plastic plug crumbled. I put the wire connectors directly onto the bulb. Btw this happened to the low beam bulb which works fine but high beam on that side no longer works.
Also the left turn signal no longer works. I removed the high beam bulb and tried turning it on, it does burn very dimmly
Reason: Adding to
