Old Sep 13, 2024 | 11:10 AM
M60A3Driver
Default Re: No start, but print plate was soldered !
Originally Posted by Temesta
I own my crossfire for over 10 years now. In the beginning there was that 'mistery no start' problem. I soldered
the print plate and it was actually fixed for many years. Now suddenly almost once a week, my car does just not
start anymore. If I turn the key, dashboard, radio etc... goes online but the engine does nothing. I rechecked the
print plate and the soldering still seems to be OK.
It does not seem to be the "skreem" issue because in that case the engine would crank. In my case it remains totally dead when I turn the key.
When I disconnect the battery (not sure this is solving the issue) and wait for a least 24hours before reconnecting, the car starts again.
Any suggestions what I could do to fix this ? Can I do some kind of active reset instead of just waiting?
Thanks!
I would think it's the Relay Control Module. The soldering may be good, but the relays inside may have gone bad. Have you tried replacing the RCM and see if the problem goes away?
If the fuel pump relay has failed the car won't start. You can test this by using a rubber band a round it to keep it closed.Also, check the fuses on top.
