Thread: Headlight issue
Old Sep 13, 2024 | 11:15 AM
M60A3Driver
Default Re: Headlight issue
Originally Posted by BeehappyjamAdaMay2020$
Yes the plastic plug crumbled. I put the wire connectors directly onto the bulb. Btw this happened to the low beam bulb which works fine but high beam on that side no longer works.
Also the left turn signal no longer works. I removed the high beam bulb and tried turning it on, it does burn very dimmly
Try replacing the front and rear turn signal bulbs and see if that fixes it. Also make sure you didn't blow any fuses.
For the high beam, clean the where the bulb contacts the socket and the metal part of the bulb itself. It may be a bad ground that's making it go dim. You can use contact cleaner, or spray a little brake cleaner on a rag and wipe both surfaces.
