Old Sep 16, 2024 | 03:47 PM
amx1397
Default Re: Information on our differential
Up date on the wavetrac and some torque numbers
There is really only one oil
to avoid: RedLine Oil (any type)
We recommend:
Motul 300
Synergyn Syngear II
80/140
Fuchs Silkolene SYN5
75/90
We are testing Royal
Purple 85/140 this summer and looks like it will be a good one,
too.
correction on the Royal Purple gear oil... 'Max Gear' 75-140w
I just read the bottle again and it specifically states that it has 'friction modifiers'....
DO NOT USE THIS OIL for your Wavetrac LSD...
they recommend using Motul, Royal Purple wouldn't be an issue. He just doesn't want
people running Lucas oils or the other sub-tier gear oils in there.
- Torque settings
o Rear diff bolts – 84 ft/lbs
o Front diff bolt – 33 ft/lbs
o All suspension bolts – 52 ft/lbs
o Driveshaft bolts – 44 ft/lbs
