Lug bolts
Sep 16, 2024 | 08:22 PM
permalink
amx1397
Apr 2008
6,723
463
Indialantic Fl./blairsville Ga
Re: Lug bolts
Stock Crossfire and Mercedes use a cone type ball seat,, aftermarket use a taper seat.
as for length the front (you can use longer bolts) and because of the offset of the stock rims,
you have 30 offset on the front, where as on the rear you have 20 offset ,that is why the stock
lug bolts are the same front and rear. I posted all this info 5 or 6 years ago,, but here it is again.
Bolt taper and ball
Bolt taper and ball
crossfire
crossfire tire specs
19" tire chart Tire size max height 26.9 stock 26.0 285/35-19= 26.9 & 11.2 wide see tire chart
18"tire chart
20" tire chart
ball and taper bolt. hope u can see this
another 20" tire chart
M60A3Driver
amx1397
View Public Profile
Send a private message to amx1397
Find all posts by amx1397
