Re: Lug bolts
sounds good ,,the best way to check if a lug bolt works is to insert it into the rim ,,, and have 5/8" sticking out the back of the rim.
then put a little puddy on the threads tighten the rim on the car at least with 3 lug bolts and remove the one with puddy
and make sure it goes through th hub , with 1 and only ONE thread... the front bolt can go through by as many as 5 to 7 or more threads jim
