Old Sep 19, 2024 | 08:13 AM
dedwards0323
Default Re: Valve Cover Fastener Torque
Originally Posted by UrbanE
If you’re going to do this, contact Rob at Needswings for new bolts. You never want to reuse the old ones.
This is a required step when performing maintenance on leaking crankcase breather covers. The factory screws are an aluminum alloy and attempting to re-use these screws ends up just 'stretching' the screws which means the RTV seal will fail. The larger screws that hold the valve covers on do not need to be replaced (IMO).
I also recommend checking the valve cover screw torque setting as a routine maintenance task every year or 2. I have found these loose during a re-check in the past. And by doing this, I haven't had any leakage from the valve cover gaskets so far.
