Old Sep 21, 2024 | 01:44 PM
bbrisken's Avatar
bbrisken
Default Re: Engine Problem Identification
Originally Posted by bbrisken
Greetings,
I wiped the areas that were once wet and came back with what appears to be oil. That being said, I was thinking about starting it and letting it get hot enough to spew again to give it an immediate check. Do you think this is advisable? The knocking noise is disturbing.
Thanks again for your input!
Brad
Finally remembered how to log back in and after letting it sit for six months or more, I towed it in, and they replaced the water pump as you all suggested! They replaced the battery then I left the dome lights on and now even with a jump it won't turn over. What fun this one has been! Thanks again for all the help!
