M60A3Driver
I would think it's the Relay Control Module. The soldering may be good, but the relays inside may have gone bad. Have you tried replacing the RCM and see if the problem goes away?
If the fuel pump relay has failed the car won't start. You can test this by using a rubber band a round it to keep it closed.Also, check the fuses on top.
Thank you for your response and solution. I haven't yet checked the RCM module like you indicated. But now suddenly and magically it is fixed.
The last 3 weeks no more problems ...
What a strange car ....
