Old Oct 6, 2024 | 03:41 PM
  #103 (permalink)
zip439's Avatar
zip439
Default Re: Index of Crossfire problems and repairs
Originally Posted by Kjmaupin
Hi I have a problem that I can’t seem to get any info on. When I turn my headlights on my brake lights come on. Brakes work fine and normal when head lights are off. Any help would be so appreciated
Hi Kjmaupin! Welcome to the forum.
First let you know that the brake light switch is under the dash above the brake peddle. However, be advised they are not all the same nor is the wiring. Depends on car, SRT6 and Limited are wired different and there may be something else involved if you have a standard transmission vice the automatic. So if the switch is the problem be sure you get the part number from the one you have and get the proper replacement. There is also a relay in the under hood fuse box.
Anything else going on? Does the wing want to stay up, or cruise control not work?
The wiring diagrams are available free for download in the document section of this website; Good place to start.
And for your info it is best to start a new thread when you have a problem. This would have been better placed in the Trouble Shooting section or Exterior Lighting. Perhaps a moderator will move it.
