Old Oct 6, 2024 | 05:29 PM
mikemadeit94's Avatar
mikemadeit94
Default Re: Blown Head Gasket 60k Miles
Update I checked the oil, it looks normal I'm assuming the coolant hasn't mixed and I'm having compression loss in my coolant system as when I turn the car on and let it run for a couple minutes I remove my radiator cap and hear a hiss like built up pressure. As long as I've had the car, the motors only overheated twice for a second when I threw a belt and I instantly pulled over same when I blew a radiator hose. What direction should I go now, does anyone suspect other motor internals are damaged is there anything I should look out for? At this point I'm debating weather to attempt to install a new gasket, or swap a used motor. As far as a motor swap will anything electronic have to change or be programmed?
