Old Oct 7, 2024 | 09:18 PM
mikemadeit94's Avatar
mikemadeit94
Default Re: Blown Head Gasket 60k Miles
Are you seeing any white smoke coming from the exhaust?
Does the exhaust have an anti-freeze smell to it?
Look for weeping below the water pump, split hoses, cracked bottom of the reservoir tank, bad seal on the cap, leaking drain valve at the bottom of the radiator, etc...
So I've tried to inspect everything related to the cooling system and found nothing I'm going to try to go over everything again tomorrow to be sure. My driveway just got seal coated and I parked the car on a piece of cardboard tonight. Upon letting the car warm up there does seem to be a bit of white smoke I'm over in PA and its starting to get chilly over here I'm assuming that's normal but there does seems to be a strange smell can't tell if its antifreeze or not, the white clouds disappear upon warmup. I also topped the res off just to be sure when I installed the radiator there wasn't some kind of air bubble. The coolent looks a bit dirty it was yellow now it's a bit darker but I did install a used radiator without flushing so it's hard to tell. As far as my water pump something does not sound to healthy idk if its the bearings but it does not sound great. I can't remember if it was ever replaced.
