Old Oct 8, 2024 | 09:35 PM
red_2005_convertible's Avatar
Default Re: Going into limp home mode within the first ten to fifteen minutes of driving
Limp mode suggests it's an automatic, but .... Is it an automatic? have you checked under the passenger carpet for water damage? (Might be a TCU issue). Have you read the DTC codes? Are you leaking transmission fluid - low fluid levels or leaks around the electrical connector in the transmission could cause you to go into limp mode.
