Old Oct 9, 2024 | 03:33 AM
M60A3Driver
Default Re: Blown Head Gasket 60k Miles
Originally Posted by mikemadeit94
I appreciate the reply! Is there any information related to this repair, I've tried to search around and can't find much about it. Im half way mechanically inclined but I've never done something this in depth kind of nervous and excited at the same time lol is this motor the M112 Mercedes?
Yes it is the M112 engine.
I would bet on the water pump. It's probably failing.
Try this: With the engine off, loosen the tension on the drive belt. Grab the water pump pulley and pull up and down on it. If it moves, clunks, or leaks it's finished and should be replaced.
Just my opinion, but I'd rather replace a water pump and see if that solves the problem than tear the heads off.
Also, since you have to drain the fluid anyway, flush all of the fluid in the block and radiator, then replace with new. If possible, pressure test the radiator.
There are videos on how to flush the radiator and posts on here about it as well.
Good luck!
