Thread: Key won't work
Old Oct 10, 2024 | 01:01 PM
ZERACER
Default Re: Key won't work
Where did you get those procedures for programming a Chrysler Crossfire key?
For everyone's convenience, here are the procedures from the Service Manual. I just got my second key and it worked perfectly after I did the following:
Keyless Entry Transmitter - Standard Procedure - Transmitter Programming.
The Remote Keyless Entry (RKE) Transmitter(s) can be programmed by the customer without special tools. Transmitter programming by the customer is done by performing the following steps:
1. Press either the lock or unlock button momentarily twice.
2. Turn the key in the ignition switch to the ON/RUN position within 30 seconds.
