Old Oct 10, 2024 | 01:36 PM
BrushRoadster!'s Avatar
BrushRoadster!
Default Re: DIY Eccentric Bolt Install
Thank you! That clarifies a LOT!
I want a solution to my tire eating problem, but I don't have any suspension experience, so I'm just dipping my toes in the water and trying to learn about what it takes to correct the Crossfire suspension. I ordered a new control arm kit from FCP Euro, which is due next Tuesday, and now I wanted to see if I can correct the problem with the heavy wear on the inside of the tires.
Could the worn ball joints be a problem contributing to this? Since I am changing the arms and the ball joints, should this rectify this problem? Or would it be advisable to install the eccentric bolts as well?
