Re: Turn Signals Stopped Working
If you watch Paul's video that I posted in post #8 more than likely this solution will fix the intermittent operation of the turn signal. The process of disassembling the steering column and removing the switch assembly is not a very difficult process. The only sensitive area related to this process requires handling the airbag sensor causiously.
Cheers
