Old Oct 17, 2024 | 03:18 PM
Valk
Default Re: Maintenance indicator
Originally Posted by DT123
Hello, I'm a new user and I just purchased a 2004 X-fire and it didn't come with an owners manual.
Attached is a maintenance indicator signal and I'm trying to understand what it means prior to taking it in for service.
It has 2 wrenches followed by numbers 9200. The number has changed to 9300 now. Any help would be appreciated.
The way to reset this display ......follow this procedure and it will reset to display "7000" (miles until next service is needed)
RESETTING THE FSS MAINTENANCE INDICATOR AFTER AN OIL CHANGE
1) Move the ignition switch to the “RUN” position
2) Within 4 seconds of moving the ignition switch into the
“RUN” position, press the reset button for the trip odometer
twice within one second The display for the FSS service
request is activated for 10 seconds
3) During the 10 seconds the FSS service request is displayed,
move the ignition switch to the “OFF” position
The FSS service request will continue to be displayed
4) Press the reset button for the trip odometer and
hold
5) Move the ignition switch to the “RUN” position
6) Continue to press and hold the reset button for the trip
odometer (about 10 seconds) until the audible signal
sounds and the new start distance "7000" appears in the display
The tool symbol should disappear at this time.
