Thread: Convertible Top
Old Nov 3, 2024 | 09:52 AM
DualSportDad's Avatar
DualSportDad
Default Re: Convertible Top
You most likely have a hydraulic leak and there isn't enough pressure to latch the rear bow. If you can get the top open to where the trunk will open again I'd do that and then manually close the top and not touch it again till you get the system repaired. Keeping the trunk latch operational is key if you don't have a scan tool to open the trunk once it has been blocked.
