Old Nov 25, 2024 | 01:14 AM
M60A3Driver
Default Re: BAS/ESP and ABS light on. Scan Tool: iCarSoft i980 for MB
Originally Posted by mikespine
I have scanned all modules using the iCarsoft 980i and all modules "passed" with the exception of the Transmission TCM having 1 fault: P2314. I have tried to erase the code and the scanner said it's successful...but it's still there. (you are correct-it's not a Crossfire code).
Regarding the BAS/ESP lights: I'm going to put the original throttle body back on and remove the 74mm to see if the BAS/ESP lights go off. I wonder if the 74mm throttle body or my install could cause the BAS/ESP and ABS lights to come on. Can a throttle body be bench tested? I have no idea how to do it.
I did remove the spark plug wires and coil pack only on the passenger side when I re-torqued the valve cover bolts. The code coming from the Innova 6100p scanner did mention ignition coil 5 P2314. (I believe coil pack 5 is the middle one on the driver side.) So I switched the 4 and 5 coil- no change.
Thanks again for your response. I'm still reading and thinking about trying to solve this issue. The Crossfire is still running well and I have been assured I will not be stranded. I'm open for all input. Thanks.
Just a thought, are you sure the plug wire is seated all of the way on the spark plug? Also, when I did my plug wires, I broke 3 of the coil pack connectors and had to replace them. You might want to see if they are good.
