Old Nov 25, 2024 | 11:36 AM
  #130 (permalink)
Hatinana's Avatar
Hatinana
Default Re: Convertible Top Sensors
It's not broken, but it won't lock.
Sorry for not being clear enough
Open the latch
Power window automatically moves down from top to bottom
It just beeps but doesn't work
At that time, the trunk lock was not engaged, so the trunk could be opened
The electronic trunk lock has been removed and confirmed to work with a separate power source.
Vacuum unit remote control lock unlock operation normal
The room light doesn't go off even when locked, but goes off in manual mode
I checked the left and right fuses in the engine room and they were not blown.
It opens manually, but when it is open a beep sounds for a while.
When there is pump pressure, if you pull out the fuse, the pressure will disappear
Open button, open the latch, the glass will automatically lower, but the red light will still be on
