Re: esp-bas code 1330 Wackamole
ORC 90F5 =B10F3 if not active stored codes could be intermittent (corroded, pinched, chafed wiring)
from 2008 service manual: Measure the resistance of the wheel speed signal circuit between the ORC harness connector and the CAB harness connector. Is the resistance below 5.0 ohms?
YES >> Replace the ORC
NO >> Repair the wheel speed sensor signal circuit for a open.
