Jaymon
Thank you Mark, for your words. I found the info for the grounding cable precisely in the post you mention. Would you consider necessary to add more grounding points to alternator, etc?
As for the volt meter, I suspected a $3 device would not give "accurate capacity readings" (note my quotation marks on original post😅
, but it gives some data as for percentage and voltage output, doesn't it? Should I not trust them either?
Many thanks for the technical explanation and Merry Xmas. 🤝
There is also a ground strap that goes from the transmission to the body. It gets corroded and should be replaced.
Here's a post I did on replacing it.
Replacing ground strap LINK
